FS: H and R wheel spacers dra 50mm - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: FS: H and R wheel spacers dra 50mm (/showthread.php?tid=5432) |
FS: H and R wheel spacers dra 50mm - Dieselsec - 03-16-2014 I have for sale 2 pairs of H and R dra Wheel spacers. 50mm wide each. That will give you 100mm extra width on each axle. I bought these so I could fit a set of nice alloys I had but obviously because it messed up the offset the wheels protruded out too far. I never even opened one box and the other I put on to try the alloy, put the jack down and said no. These bolt to the hub with the fixing bolts included. Much safer. Ideal for a wide body conversion. you can see a pic of my alloy on the car. as there are 4 x 50mm spacers, I will sell seperatly i.e. as one set or as two. I bought these from Germany. Looking for 400 euro RE: FS: H and R wheel spacers dra 50mm - Dieselsec - 06-01-2014 Edit: price is 200 euro. |
