ALDA removal & refitting - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: ALDA removal & refitting (/showthread.php?tid=5479) |
ALDA removal & refitting - Jambo - 03-30-2014 Hi Guys, I need some advice. I have refitted the mechanical IP on my OM606. The motor is still out of the vehicle. I now see that the access to two of the glowplugs is very compromised. One I can easily sort by removing the oilfilter housing, the other requires either the removal of the IP or removing the ALDA and refitting it. I want to know: Can I remove and refit the ALDA or will I disturb settings done. Is the ALDA connected to anything inside the IP or is it just a rod that pushes on something? Thanks in advance. RE: ALDA removal & refitting - Druk - 03-30-2014 The ALDA unscrews from the IP leaving just the rod protruding. It's not physically connected to anything. There may/may not be shims underneath which you should recover. Not sure about that though. |
