JDM diesel engines - Printable Version
+--- Forum: Non MBZ Diesel (https://www.superturbodiesel.com/std/forumdisplay.php?fid=10)
+--- Thread: JDM diesel engines (/showthread.php?tid=550)
JDM diesel engines - totaldisaster - 07-23-2009
Any relevant info out there? I see some interesting Nissan engines.. but I can't find any four-bangers.
http://en.wikipedia.org/wiki/Nissan_TD_engine
some models of Nissan's TD series have 4 cyl
They have a straight 6 under the RD and TD series.. but its too much power.
RE: JDM diesel engines - ForcedInduction - 07-23-2009
Look in the "complete engines" section of eBay, lots of JDM diesels and front clips.
RE: JDM diesel engines - totaldisaster - 07-23-2009
as much as i hate Toyota... the 1-N and 1-NT are looking really nice
So far the only Co. selling JDM diesels on sheeshBay is Soshin, they have a bunch of vids on doucheTube.
^^ ..and they fit in a @#$^ Tercel!
RE: JDM diesel engines - GREASY_BEAST - 07-27-2009
I-DTEC is coming to the U.S.A. in an Acura
RE: JDM diesel engines - Kiwibacon - 08-11-2009
The Nissan TD engines are suited to a 4wd or light truck, they're not passenger car engines.
A very tough engine with long stroke and indirect injection. Close to bullet-proof but not that good on fuel.
Other nissan 4 and 6 cyl engines.
LD28 - 2.8L 6 cyl indirect injection diesel.
LD20 - 4 cyl version of the above.
CD20 and CD20T - later versions of the LD20, T is turbocharged.
RD28T - later version of the LD28
YD22 - 2.2L 4 cyl direct injection diesel, range from a 77hp non turbo with distributor pump to a commonrail turbo intercooled with about 180hp.
YD25 - bigger capacity version of the YD22, again ranges from non-turbo distributor pump to commonrail turbo intercooled.
ZD30 - 3L engine which replaced the TD27T and TD42, has a reputation for blowing up, caused most likely by sensor malfunction. Reports say they go really well before they blow. Replaced by the YD25.
Lots more too.
RE: JDM diesel engines - Oldbeaver - 04-25-2010
Another Nissan diesel engine:
A 1996 RD28
See https://sites.google.com/site/rd28engineswap/
OldBeaver
(08-11-2009, 01:31 AM)Kiwibacon The Nissan TD engines are suited to a 4wd or light truck, they're not passenger car engines.
Lots more too.
RE: JDM diesel engines - ForcedInduction - 04-25-2010
Despite the lack of turbo, thats pretty darn cool. Do you have any installation pictures? What transmission do you use?
