Re-weld BMW 6spd - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Re-weld BMW 6spd (/showthread.php?tid=5595) |
Re-weld BMW 6spd - F.R.A.S - 05-16-2014 Just posting two pictures for you of a rewelded gs6-37dz gearbox (don't mind the writing on the gearbox). This is made for a single mass flywheel. The gearbox is a smaller cousin to the gs6-53dz that can withstand a nuclear war. But this is a tough bastard also... Only rated for 370Nm of torque by ZF, but the older 5spd where only rated for 320Nm and they have been proved to cope with KNm here in Sweden. This smaller gearbox is easier to fit in older cars with narrow tunnels. RE: Re-weld BMW 6spd - Duncansport - 05-16-2014 nice welds! Looks great RE: Re-weld BMW 6spd - raysorenson - 05-16-2014 How to you clean dirty cast aluminum before welding? RE: Re-weld BMW 6spd - Simpler=Better - 05-16-2014 (05-16-2014, 12:56 PM)raysorenson How to you clean dirty cast aluminum before welding? You need to heat the oil out of it. Be careful not to warp it or get so hot that it weakens things. Also, cleaning with alyminym prep fluid and a brand new brush helps too. Always pre-heat before welding too. RE: Re-weld BMW 6spd - F.R.A.S - 05-16-2014 Smaller stuff we usually put in the blaster cabinet. But to be honest, the casting in this one was super clean so it was very easy to weld, and some cleaning with the angle grinder usually does the trick. We do a lot of oil pans and such and for sure it can be a pain in the a** RE: Re-weld BMW 6spd - raysorenson - 05-16-2014 Thanks for the tips guys! |
