606 diesel 3.0ltr info - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: 606 diesel 3.0ltr info (/showthread.php?tid=5674) |
606 diesel 3.0ltr info - gary andrews - 06-18-2014 hi i am a newbee .what I'm after is simple answers as new with diesels.what i want to do is transplant the 606 from 99 e class .would like it as simple as can be i.e. no electrics,want to fit larger turbo heading for a round 350-400hp with not much lag. what parts do i need i.e. turbo pump,and what do i need to do to the engine to achieve what i want .sorry if this has been done before but I'm a crap reader but i weld good cheers gary RE: 606 diesel 3.0ltr info - willbhere4u - 06-19-2014 (06-18-2014, 02:27 PM)gary andrews hi i am a newbee .what I'm after is simple answers as new with diesels.what i want to do is transplant the 606 from 99 e class .would like it as simple as can be i.e. no electrics,want to fit larger turbo heading for a round 350-400hp with not much lag. what parts do i need i.e. turbo pump,and what do i need to do to the engine to achieve what i want .sorry if this has been done before but I'm a crap reader but i weld good cheers gary you will want the injection pump off an om603 300d and probably a holset turbo hx40 and you will need to have the pump built and tuned for that power level. RE: 606 diesel 3.0ltr info - gary andrews - 06-23-2014 cool so I've got my hx40 ,603 pump tuned ,what else do i need the do to the engine i.e. ignition and what power would that return cheers RE: 606 diesel 3.0ltr info - cho - 06-23-2014 (06-23-2014, 02:56 AM)gary andrews cool so I've got my hx40 ,603 pump tuned ,what else do i need the do to the engine i.e. ignition and what power would that return cheers as you went from electric pump to mechanical you will have to fab linkage,set a few gauges to monitor temps ...powah? ... 450+ ![]() ![]() ![]() depending of car transplanted you may have to fab engine/motor mounts..etc.... edit: search for dieselpumpuk's videos on youtube .... . RE: 606 diesel 3.0ltr info - gary andrews - 06-23-2014 sounds good how much hp with a hx35 RE: 606 diesel 3.0ltr info - cho - 06-24-2014 (06-23-2014, 04:44 PM)gary andrews sounds good how much hp with a hx35 not sure but guys used om605 and hx35 and produced 380hp....fwiw . RE: 606 diesel 3.0ltr info - Hario' - 06-25-2014 Get a HX35 cheap from ebay, but make sure it has an exhaust housing no bigger than 12cm2, this number is stamped in the exhaust flange entry to the scroll. RE: 606 diesel 3.0ltr info - gary andrews - 06-26-2014 hario,was thinking the same did you do your pump on yours if so where as your only down the road from me cheers |
