what are the symptoms of a bad ip? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: what are the symptoms of a bad ip? (/showthread.php?tid=5675) |
what are the symptoms of a bad ip? - NapaBavarian - 06-20-2014 I have a couple cars that are giving me fits at the moment, what would indicate that the ip is to blame? RE: what are the symptoms of a bad ip? - Torkey - 06-20-2014 IPs seldom fail. What kind of problems are you experiencing? RE: what are the symptoms of a bad ip? - sassparilla_kid - 06-20-2014 Without knowing the symptoms exactly could be anything from bad fuel to dirty junk in the ip to sticking delivery valves, or could be timing, stuff like that RE: what are the symptoms of a bad ip? - NapaBavarian - 06-21-2014 One car has an idle issue, will start at wide open throttle and after a little warmup it can be run at any normal rpm, but wont idle, foot off throttle, car dies. Second makes little to no power, I haven't been able to look at it much, but I did change fuel filter. I'd like to tear it appart and replace all fuel lines, I may try a different lift pump too. It seems better once it warms up, but still hardly makes any power. RE: what are the symptoms of a bad ip? - Torkey - 06-21-2014 I forget to ask... What year and models are these cars? And did the problems start suddenly or was it a gradual and progressive type of thing? RE: what are the symptoms of a bad ip? - NapaBavarian - 06-22-2014 The car that dies came as a non runner, I think glow plugs may be dead but so is my multimeter so I cant verify. 87 300sdl The other is an 82 300sd that started as an intermitant problem uppon startup and gradually became worse. RE: what are the symptoms of a bad ip? - Tito - 06-22-2014 for the one that keeps stalling you can try to turn op the idle. Top external screw on the governor. I don't remember if you should turn it in or out. RE: what are the symptoms of a bad ip? - MFSuper90 - 06-23-2014 The one that has little to no power probably has a clogged ALDA line. Just had to clean the soot out of my buddies 300SD, it was the slowest thing id ever driven before we fixed the alda RE: what are the symptoms of a bad ip? - cho - 06-24-2014 , the 2 symptoms I have witnessed were worn DV's - you have to change these, no cleaning helps /significant shakes is the sympt./ messed elements (via upper nuts) - back to adjustment table /no able to start,uneven fuel,severe shakes/ . |
