OM602 - Which Charger i need for 220 PS ? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM602 - Which Charger i need for 220 PS ? (/showthread.php?tid=5687) |
OM602 - Which Charger i need for 220 PS ? - swatmugga - 06-26-2014 Hi Im looking forward to build a Turbocharger on my om602. I like to get around 220PS with an Charging Air Cooler. The Engine should get a good lifetime with the power, it should not crash after a few miles. What charger you can recommend ? I like to use 7mm Pump elements, 1,4 Bar and an DIY exhaust with 2,5 inch. Thanks a lot |
