om617 912 crank on 952 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om617 912 crank on 952 (/showthread.php?tid=5739) |
om617 912 crank on 952 - carlitosgy6 - 07-22-2014 It is possible to interchange turbo and no turbo crankshaft? RE: om617 912 crank on 952 - Simpler=Better - 07-22-2014 The turbo crank is hardened, and I tihnk the oil pump drives are different. Other than that I *think* they're the same. RE: om617 912 crank on 952 - carlitosgy6 - 07-22-2014 Thats my biggest doubt, the gear for the oil pump chain, maybe i can install it but i don't want to take apart a perfectly running engine just to find is completely different RE: om617 912 crank on 952 - DeliveryValve - 07-23-2014 It won't work. The oil pump drive is different. Best to get a turbo crank. RE: om617 912 crank on 952 - carlitosgy6 - 08-08-2014 The crank is different, the area for the oil pump chain on the turbo engine makes the crank longer, so they are totally incompatible |
