Planning om603 hx35 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: Planning om603 hx35 (/showthread.php?tid=5793) |
Planning om603 hx35 - bl4z33r - 08-19-2014 Hello I Want to buy a w124 with om603 turbo. but before i buy the car i want a list of what parts i need. thats why i want some help. I thinking around 350hp What do you think about Holset hx35 but is it better to go for the Dieselmeken 7.5mm or the 8mm ? please explain me why and is it some more i need to get this running this is my first diesel Prosjekt. RE: Planning om603 hx35 - Gforce - 08-19-2014 you also need an intercooler and your intake manifold needs to be changed RE: Planning om603 hx35 - bl4z33r - 08-19-2014 (08-19-2014, 04:23 PM)Gforce you also need an intercooler and your intake manifold needs to be changed okei can i go for the 8mm pump? what is the downside ? or is more better? RE: Planning om603 hx35 - bl4z33r - 08-24-2014 nobody have some advice? for me ? RE: Planning om603 hx35 - Hario' - 08-26-2014 8mm elements will give you some overhead for fueling if you wish to go for more boost/power in the future. There are mixed reviews about idle quality with bigger elements but everyone seems to think they will be fine. Turbo, manifold, pump, elements, fitting elements, intercooler, ALDA, pipework, EGT gauge, Boost gauge, RE: Planning om603 hx35 - raysorenson - 08-26-2014 If you have an early 603, make sure you at least replace the head gasket before going big with boost and fuel. IMO, 7.5mm elements will make more power than your 603 can handle. RE: Planning om603 hx35 - Insane190d - 08-26-2014 I have an 8mm pump on my om603 idles fine, only have it about half the fuel it will flow but its there when I want more RE: Planning om603 hx35 - bl4z33r - 08-29-2014 what turbo you have insane190d ? and what boost do you have? RE: Planning om603 hx35 - Insane190d - 09-03-2014 (08-29-2014, 11:32 AM)bl4z33r what turbo you have insane190d ? and what boost do you have? Its an hx35 off a 2nd gen dodge cummins. I went to home depot and bought a 30psi boiler pop off valve and plumbed it into my intake, works pretty good blows off at 30 and stays between 27 & 30psi |
