WANTED: Mercedes 2.5 TD / 3.0 TD Bosch Pump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: WANTED: Mercedes 2.5 TD / 3.0 TD Bosch Pump (/showthread.php?tid=5813) |
WANTED: Mercedes 2.5 TD / 3.0 TD Bosch Pump - silverzx - 08-29-2014 A very long shot but if you don't ask, you don't get.. After a 2.5 TD bosch pump for a Mercedes, the older OM602 version not the semi-ECU OM605 version. Would also consider a OM603 3.0 TD bosch pump. Thanks! RE: WANTED: Mercedes 2.5 TD / 3.0 TD Bosch Pump - llopness - 08-29-2014 would a 602 2.5 NA pump work? |
