Any information on MB Vito transaxle ratios? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Any information on MB Vito transaxle ratios? (/showthread.php?tid=5866) |
Any information on MB Vito transaxle ratios? - Jetmugg - 09-25-2014 I'm trying to find out the 1-5 and final drive ratios for a Euro-spec Mercedes "Vito" 5-speed front-wheel drive transaxle. MB # A6382601800 Getrag # 711698 080258 As always, any information would be appreciated. Steve. RE: Any information on MB Vito transaxle ratios? - CRD4x4 - 09-26-2014 Idk nothing about Vito gearboxes but I think a Getrag 6-speed transaxle from a Mini Cooper S would suit you well. GS6-85BG They were even available (not here) mated to a diesel so I'd assume that gearbox would be best. RE: Any information on MB Vito transaxle ratios? - Jetmugg - 09-26-2014 The thing that's nice about the Vito gearbox is that it would be a direct bolt-up to an OM60x block. I will look into the Mini Cooper S box, also, as well as the GM F-40 6-speed gearboxes. I have the Mercedes EPC, but still haven't found the Vito gear ratios. Steve. The Mini Cooper diesel 6-speed gearbox gives an effective drive ratio of 2.41:1 in 6th gear which is pretty good. My current 4-speed setup is 2.47:1. A "taller" ratio would be even better for Bonneville. Steve. RE: Any information on MB Vito transaxle ratios? - CRD4x4 - 09-26-2014 So far I've found this quote from a Daimler press release: "Its defining feature is a particularly broad gear ratio spread, with a short first gear (i=5.076) and a long sixth gear (i=0.675) designed to keep the engine speed low." But, this is for the 6-speed... (09-25-2014, 04:12 PM)Jetmugg I'm trying to find out the 1-5 and final drive ratios for a Euro-spec Mercedes "Vito" 5-speed front-wheel drive transaxle. RE: Any information on MB Vito transaxle ratios? - Jetmugg - 09-26-2014 The newer model Vito's (I think where the 6 speed is available) is rear wheel drive as well. I need to find a FWD transaxle design with the longest top gear readily available. My current VW 4-speed has a 0.71 4th gear and a 3.48 ring and pinion, giving an effective final drive of 2.47. For the next project, I really want to find something with an even "longer" (numerically lower) final drive. The F40 6-speed transaxle has a 0.62 6th gear and a 3.55 R&P, which yields a 2.20 effective final drive. That's a good number. RE: Any information on MB Vito transaxle ratios? - Petar - 09-26-2014 I don't know the ratios but i rode in a Vito 110 CDI a couple of months ago and if i remember i correctly it turned a bit under 3000rpm at 120Kph. 120 Kph is something like 75 Mph. RE: Any information on MB Vito transaxle ratios? - Devito - 08-26-2015 Hi Petar, I just read your post regarding Vito 638 Manual ratios. All the following are to 1. (:1) 1st: 4.25 2nd: 2.35 3rd: 1.46 4th: 1.03 5th: 0.813 FD: 3.947 (A6382601000, A6382601800 & A6382602200) (108cdi) FD: 3.842 (A6382602400 & A6382602000) (110cdi) FD: 3.737 (A6382601900 & A6382602300) (112cdi) You looking for a taller final drive ratio? Go for a 112cdi gearbox. You will need to correct the speedo via MB Star diagnostic machine. Cheers. RE: Any information on MB Vito transaxle ratios? - Hario' - 09-07-2015 The FWD 604 powered 1999 Vito my friend had (UK spec) was transverse, you're talking about a north-south engine & FWD transaxle & OM60x Vito? RE: Any information on MB Vito transaxle ratios? - CRD4x4 - 11-08-2015 Jetmugg, I'm bringing this thread back from the dead because of an oddly configured car that I recently learned about here in the USDM. Its a longitudinally oriented (north/south) inline 5 cylinder engine with a 5 speed manual transmission and FWD...the Acura Vigor! It had a nearly 50/50 weight ratio despite having a 2.5L 20V slant 5 & FWD. Info isn't exactly easy to find but it may be worth looking into for a 5 speed transaxle solution. RE: Any information on MB Vito transaxle ratios? - Hario' - 11-10-2015 (11-08-2015, 06:41 PM)CRD4x4 Jetmugg,Lots of the European VW / Audi stuff is north south & fwd, less parts differences between the 4wd versions I guess. What about the gearbox from a Renault master TD? It's north/south, cheap and strong (people use them for Ultima kit cars over here). RE: Any information on MB Vito transaxle ratios? - Petar - 11-10-2015 I think Jetmugg needs a transverse transaxle, not a longitudal one. But anyway he already decided on using VW TDI six speed rewelded to mercedes pattern, i think FRAS already made it. |
