603 accesorys on a 606 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: 603 accesorys on a 606 (/showthread.php?tid=6011) |
603 accesorys on a 606 - TurboTim - 11-22-2014 When doing swap can you move all you old AC pump and ps pump over? Alternator? RE: 603 accesorys on a 606 - benzguy - 11-22-2014 I did it the other way I have a 95 E300D the original engine was a 606 and I replace the 606 with a 603 and I used all the accessories from 606 they fit you can use the accessories from a 603 into the 606 RE: 603 accesorys on a 606 - TurboTim - 11-22-2014 Haha your a funny guy to do that. Thanks for the info! So it should work then. Good to know. |
