om603 6mm elements - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: om603 6mm elements (/showthread.php?tid=6066) |
om603 6mm elements - PedroFerreira - 12-16-2014 how much hp can 6mm elements do in om603? RE: om603 6mm elements - baldur - 12-16-2014 'bout 300. RE: om603 6mm elements - PedroFerreira - 12-16-2014 can do more that in om605? RE: om603 6mm elements - baldur - 12-16-2014 No it'd do less, since the 605 only has 5 cylinders while the 603 has 6 of them. RE: om603 6mm elements - PedroFerreira - 12-16-2014 the om605 whith 6mm (stock) can do 260hp.om603 whith 6mm ip can produce 240?or less? RE: om603 6mm elements - baldur - 12-16-2014 Given that OM603 has 6 cylinders and thus one extra pump element, it'll be able to produce about 300 horsepower. RE: om603 6mm elements - PedroFerreira - 12-16-2014 but the om605 had 20v and om603 only 12... RE: om603 6mm elements - rafael cotrim - 12-17-2014 Pedro , Is what i already have told you, I guess.... RE: om603 6mm elements - MrHope - 12-26-2014 Om605 with 6mm on dyno 274hp on crank. http://www.maxxtuning.se/kundbilar/effektmatning-orginal-ecu/232whp-mercedes-w123--jim/ RE: om603 6mm elements - bruno_pinho - 12-26-2014 (12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank. I do not believe in 174 to 1.5bar... RE: om603 6mm elements - Petar - 12-26-2014 (12-26-2014, 03:31 PM)bruno_pinho(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank. What don't you believe ? That engine is only making 380 NM's of torque but with the torque curve shifted up in the rpm range to make more power. RE: om603 6mm elements - starynovy - 12-26-2014 (12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank. Very nice, is that yours? RE: om603 6mm elements - bruno_pinho - 12-26-2014 (12-26-2014, 04:35 PM)Petar(12-26-2014, 03:31 PM)bruno_pinho(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank. Sorry but I do not believe these numbers to 1.5bar ... RE: om603 6mm elements - F.R.A.S - 12-26-2014 That's not 6mm elements in that video and the owner Jim is a friend of mine. 6mm can't ever do 300hp forget about that. RE: om603 6mm elements - bruno_pinho - 12-26-2014 (12-26-2014, 05:08 PM)F.R.A.S That's not 6mm elements in that video and the owner Jim is a friend of mine. I did 260cv and 417nm with 6mm and electric pump with 1.8,1.9bar.. |
