HP WITH 6MM ELEMENTS - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: HP WITH 6MM ELEMENTS (/showthread.php?tid=6111) |
HP WITH 6MM ELEMENTS - tricipiti - 01-06-2015 Need some help. Lot of time reading forums.and im not sure about 6mm elements.some people says that you can obtain 250hp,and other people only +20 RE: HP WITH 6MM ELEMENTS - bruno_pinho - 01-06-2015 Yes, can easily 250cv RE: HP WITH 6MM ELEMENTS - raidaru - 01-06-2015 220 hp without smoke, 250 with smoke and higher EGT RE: HP WITH 6MM ELEMENTS - tricipiti - 01-06-2015 stock turbo?? RE: HP WITH 6MM ELEMENTS - F.R.A.S - 01-07-2015 45hp is what you get from a good adjusted 6mm element. You have not specified your engine so really hard to help you. AND this matter has been up in 1.000.000 threads already so try to read the forum. If you have 4cyl take 45hp x 4 = 180hp If you have 5cyl take 45hp x 5 = 225hp If you have 6cyl take 45hp x 6 = 270hp This is for om604/605/606 the older 601/602/603 makes less HP. STOCK 6mm elements gives 38hp And now you can make the math yourself. Stock turbo hahahhaha you kidding right??? Stock turbo is for STOCK POWER. RE: HP WITH 6MM ELEMENTS - DiseaselWeasel - 01-07-2015 n00b question here too; does the 603s stock turbo gain any benefits on 606? I have a couple of good ones left over and they look bigger... Goal would be around 200HP with early spool. RE: HP WITH 6MM ELEMENTS - raidaru - 01-07-2015 (01-07-2015, 05:50 AM)DiseaselWeasel n00b question here too; does the 603s stock turbo gain any benefits on 606? I have a couple of good ones left over and they look bigger... Goal would be around 200HP with early spool.if they look bigger it means later spool, also due to older design, and for 200 hp is not worth changing the turbo, a chiptuning for om606 is @215 hp ![]() RE: HP WITH 6MM ELEMENTS - DiseaselWeasel - 01-08-2015 So stock turbo is good for about 200HP? I just don't want to have it runing at the limit all the time ![]() |
