m pump in 605 - Printable Version
+--- Thread: m pump in 605 (/showthread.php?tid=6112)
m pump in 605 - gary andrews - 01-06-2015
hi i have just fitted my m pump with 7.5 elements to my 605 but to get it in i had to remove oil cooler and oil fitter housing. so do i need to block the water ways up e.g. core plugs,and the fitter housing do i need to get another one if so off what ? or what is the done thing for to sort these two cheers
RE: m pump in 605 - EDH_Performance - 01-06-2015
(01-06-2015, 05:17 PM)gary andrews hi i have just fitted my m pump with 7.5 elements to my 605 but to get it in i had to remove oil cooler and oil fitter housing. so do i need to block the water ways up e.g. core plugs,and the fitter housing do i need to get another one if so off what ? or what is the done thing for to sort these two cheers
You should be able to have the oilcooler there as that motor comes with mechanical m-pump from factoryWink
Maybe you have the om602 mechanical m-pump with the funny lump on the back of the pump?
RE: m pump in 605 - gary andrews - 01-07-2015
yes that sounds like the pump i have
RE: m pump in 605 - F.R.A.S - 01-07-2015
Cut a flat plate to mount on the back of the pump Smile
RE: m pump in 605 - Hario' - 01-09-2015
Got a picture mate??
RE: m pump in 605 - gary andrews - 01-11-2015
ive blanked the core plugs and fitter housing for now ill use external cooler later ,cheers
RE: m pump in 605 - Druk - 01-11-2015
Are you sure these oilway items aren't full-flow and you'll be starving the bearings of lube?
RE: m pump in 605 - Hario' - 01-12-2015
Well OM606 uses front mounted oil cooler so for future reference could use a OM606 oil filter housing and connect the two oil fittings together in a loop? Assming it also blocks off the OM605 water fittings in the block?
RE: m pump in 605 - barrote - 01-13-2015
hy there,
best way of doing: go in a scrap yard buy a oil filter support from a G o M, those come with oil radiator any motor have them, even the sangyoung 4 whellers. 601,2,3,4,5,6 are interchangeable, so anyone goes.
to cover the cyl head holes use expansion taps,(dont know the correct name in english) can buy them from MB or in any automotive retail store.
regards.
