OM605.960 manual pump conversion? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM605.960 manual pump conversion? (/showthread.php?tid=6187) |
OM605.960 manual pump conversion? - 10mpg - 01-30-2015 OK as some of you have seen I 'm putting an OM605.960 in my boat. I'm a Merc TD newbie but eager to learn! Out of preference I'd rather have a completetly manual injector pump on my engine primeraly because it's going to go out on the water and then there's no risk of water getting into the electrics. But I'm happy to be pursuaded otherwise, though the one thing i will not have is a key based immobiliser system or fly by wire throttle.. My engine is not coming with an ECU (as far as i know) So, what are my options? What does the injector pump i have come with? Can it be made to work? If not what should i buy? Budget is a serious issue, cheap and cheerful wherever possible, I run a small engineering workshop and can make most things so wherever possible I'd rather build it/understand it than just throw money at it.. I'm not aiming for big power, torque and fuel economy are the priority at this stage, anywhere between 120 and 140 bhp would be perfect... All advice welcome! RE: OM605.960 manual pump conversion? - Petar - 01-30-2015 This topic has been beaten to death but i will try to summarize it in a couple of sentences. Any om602/605 injection pump will bolt right on. Ssangyong OM662 2.9 pump will also work. HOWEVER only turbo pumps will have an ALDA. A non turbo pump will also work but you will have to live with some off boost smoke,adapt your driving habits to minimize it, or buy an external ALDA from dieselmeken. For 120-140 HP stock 5.5mm elements in these pumps will do fine but it is recommended to swap to 6mm elements from your electronic pump to get full power from the engine. RE: OM605.960 manual pump conversion? - 10mpg - 01-30-2015 Yes when I was searching i kept seeing references to the ALDA, didnt really know what it was, and all the posts i read assumed previous knowledge, sorry to drag up a continuing topic, but there doesnt seem to be a sticky thread for novices like myself. I'm not to worried about smoke as the exhaust is 'wet' so there should no 'clouds' I have found a supllier of Ssang yong pumps for £80 each which seems very fair, but i couldnt find any ifo on what he ALDA was wheather it was needed for a my application, or even what it did.. Is changing the elements from my existing pump to the ssangyong one a DIY proposition? if so is there a guide or a known UK facility? RE: OM605.960 manual pump conversion? - EvoPeter - 01-30-2015 If u want bigger element u send it to Dieselmeken. Changing elements is no DIY. RE: OM605.960 manual pump conversion? - Petar - 01-31-2015 ALDA is the boost compensation device, it limits fuel when not on boost thus reducing smoke. It is the round can thingy right behind the shutoff valve, it is really tall compared to the rest of the pump. There is also the older type ALDA that looks more rectangular However not all of those round cans are ALDA. Some have ADA and that is just altitude compensation for naturally aspirated engines.It looks the same as first ALDA except it isn't connected to the manifold, instead it is open to the atmosphere. But it should be possible to replace the ADA can with an ALDA. Element swapping DIY is possible but the pump MUST be calibrated on a test bench. You can just send both the mechanical pump and the electronic pump to a local pump shop and ask them to swap the elements and calibrate the pump. Any local injection pump shop should be able to do it. That Ssangyong pump sounds like a decent deal, it should also have an ALDA since it came of a turbo engine. AFAIK you never got turbo 602/603 engines in the UK. RE: OM605.960 manual pump conversion? - 10mpg - 02-01-2015 Fantastic information, thankyou very much! So if I'm understandign this correctly, all the manual pumps mentioned are capable in na form (with some adjustament no doubt) of running on a turbocharged motor without any significant alteration? If i dont care about smoke then an ALDA is inconsequential? (though for 100EUR it seems worthwhile doing just to not upset people) The ssangyong pump I can source is off a 2.9 NA engine not a turbo unit.. RE: OM605.960 manual pump conversion? - barrote - 02-01-2015 hello there, just a few things!!! buying a IP from a junkyard even if it seems cheap may have desastrous consequences. it may end up in the bin. care must be exercised, a few tricks of the kick. elements stuck, rendering the pump unserviceable unless overhauled. james watt device inside may have play (chinesse masses), if it does it has to go in the bin. and several other play inside the pump governor. search for a pump with the manufacture marks still unvoid. even if u have to pay a few euros more. BTW , alda or ada or whatever u have in there , it is interchangeable. but for a boat humm humm do the smoke bothers??? fuel consuption??? smooth idling??? RE: OM605.960 manual pump conversion? - Palmer - 02-01-2015 I see you are from the uk. Speak to dieselpumpuk. They will sort u out. Chris RE: OM605.960 manual pump conversion? - maxypriest - 02-01-2015 Yes, ring Luke up at dieselpumpuk and he'll help you out. RE: OM605.960 manual pump conversion? - Hario' - 02-02-2015 You may as well fit / made an ALDA, it is a very simple device to reduce off boost fuel, make your own from an old turbo actuator and some stainless bits of brackerty-polkery. It just connects to the inlet manifold and holds the max fuel lever down with the actuator spring until manifold pressure overcomes it and lifts (to increase max fuel). RE: OM605.960 manual pump conversion? - 10mpg - 02-02-2015 Yes it looks very simple having found a video, if it helps fuel consumption then I'm all in, I didn't realise it was that simple! Is there a guide to tuning and setting the pumps up anywhere? probably just turning the fuel delivery up a bit to cope with the extra air from the turbo? RE: OM605.960 manual pump conversion? - 10mpg - 02-26-2015 Just to raise this topic from the dead, I will be collecting my OM605 this weekend and I have a pump from a Ssangyong musso 2.9TD or order (OM662) Like i said I'm not looking for big power 120-140 will be perfect for now, I'd rather just get it working tested then tune later if need be.. So I'm going to make an fit an ALDA using a turbo wastegate actuator, I have plenty kicking around from my Saab tuning days, so I will knock something up.. Really my question is now this: do I just set the engine to the static timing (24 deg BTDC??) and bolt the pump up connect the fuel and stop turn the key and go? It cant be that simple, can it? RE: OM605.960 manual pump conversion? - barrote - 02-26-2015 hello , basic timing is 14,5º atdc. basic timing is to install pump, after u must set the perfect timing. i have a pump that can give u 200HP at least, if interested PM me for details. BTW i dont think OM 662 pump will work just like that, they are 5,5 mm element ; regards RE: OM605.960 manual pump conversion? - 10mpg - 03-02-2015 Thanks for the offer but I can't have 200HP it will blow my drivetrain apart! Is there a guide to setting timing? I was under the assumtion that 5.5mm would be fine for 120BHP? RE: OM605.960 manual pump conversion? - barrote - 03-04-2015 for 120 bhp, thats a stock 605N/A. why to bother with that few. just take the pump in and thats it. search in www.w124-zone.com there are factory manuals there. |
