-10AN Turbo Oil Drain Adapter for OM617a Block....Any interest? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: -10AN Turbo Oil Drain Adapter for OM617a Block....Any interest? (/showthread.php?tid=6259) |
-10AN Turbo Oil Drain Adapter for OM617a Block....Any interest? - Mylesofsmyles - 02-19-2015 I'm working with a machinist/fabricator to make an adapter that'll press into the stock Oil Drain hole, in the block of your OM617a, and adapt to a -10AN fitting. This would be a real problem solver for those installing different turbos, modifying manifolds, and in need of a custom oil drain line. It'd also be a nice upgrade from the stock rubber o-ring fittings. It'd be something kind of like this....this one is for a Volvo Redblock.. ![]() Am I the only one who would want something like this, or is there any other interest? RE: -10AN Turbo Oil Drain Adapter for OM617a Block....Any interest? - raysorenson - 02-20-2015 Yeah, I could use one. RE: -10AN Turbo Oil Drain Adapter for OM617a Block....Any interest? - Mylesofsmyles - 02-20-2015 I need someone's upper oil pan to send Josh, and get it made |
