W203 270cdi brakes on W124 XXX - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Brakes (https://www.superturbodiesel.com/std/forumdisplay.php?fid=11) +--- Thread: W203 270cdi brakes on W124 XXX (/showthread.php?tid=6375) |
W203 270cdi brakes on W124 XXX - barrote - 03-24-2015 Hello fine people, As mensioned above , with a small modification it is possible to fit the 300/88 calipers and double disk found in the 203 family in a w 124, in my case i choosed the 270 version. It is also possible to fit the w210 320CDI, same modification needed. modifications are: changing the position of hose, from a horizontal position to a vertical one , and cut a bit of the cylinder body to travel correctly. eliminate the horizontal theaded hole , wich can be aconplished by a bolt. thread size is 10mm/1mm install a 3.5 mm washer in the 19mm bolt wich atach caliper to suspension. thats it a very good upgrade regarding brakes. RE: W203 270cdi brakes on W124 XXX - Hario' - 04-10-2015 Most calipers bolt to most hubs, the problem is that either the caliper or the disc has the wrong offset for the combination, so yo ucan either space the caliper, or easier usually, just get the discs from your particular car that has the correct offset for your bigger caliper, usualy from the bigger engined model car. Regarding brake hoses, just get hoses made up with a banjo fitting on the caliper end, and add 50mm to the original hose length. RE: W203 270cdi brakes on W124 XXX - barrote - 04-23-2015 he hario, yep anything goes, but w124 even in the v8 version does not have such as good braking as the 203 model from 270CDI on , only the 203 AMG version have better. the rear is even better to change , only the heat shield is on the way , wich u can resolve with a small hammer ![]() anyhow , it does work is just a minor modification that any tunning used fella can achieve. regrds RE: W203 270cdi brakes on W124 XXX - DiseaselWeasel - 04-30-2015 Well, good to know! I'm currently runing R129 4-pot calipers, but they don't clear W210 7.5x16" steel wheels... But mr TÜV is NOT going to like "washers" behind calipers ![]() I'd realy like to use the 7,5x16" wheels, way easyer to mount 205/55 tyres on, it was a fight to get them on 8x16" steel wheels.... 205/55 is cheap as fcuk and very easy to get... On the other hand I truly hate floating calipers... ![]() RE: W203 270cdi brakes on W124 XXX - barrote - 05-01-2015 whats the problema with TUV, u know that if they inspect that u got to be in the certificate, where i live they do not inspect that they just measure and compare quality of braking. so.... if u really want to upgrade W124 brakes and u got to be inspected by TUV fellas , well ask MB a certificate for a W124 500E and then u have what u need. well if u can afford that. Maybe u can find in the W203/204/208/210/212 a set of brake disk that does not need spacing, or a wheel hub that u can fit in the w124. regards. RE: W203 270cdi brakes on W124 XXX - DiseaselWeasel - 05-01-2015 It's all not that easy ![]() Same with engine... I need to swap over complete W210 drive train, differential (or same ratio), gearbox, engine, oxidation catalyst, engine management etc. etc. to make it legal... And then aerodynamics & weights, tyre sizes of recepoient & donir need to be as close as possible. If I leave out one of those points - it's worst emissions category and I end up paying over 1300€ taxes per year. We can get a LOT of stuff made legal, but you have to follow very strict guidelines and rules to make it happen with reasonable expenses... Of course you can cheat your way through a approval with a mechanical pump or different differential and manual gearbox - who knows? Mr. TÜV most robably don't... But - should I run over a nun with kittens and the car gets investigated (likely with serious mods registered to the paperwork) I'm not goin to be happy ever again. So... I like to keep it legally legal. I'm too old, my boy racer days are over. Even if that means I have to do some extra work and accept some limitations. And I'm happy by doing that. I also need paperwork to make 205/55 tyres on 8" wheels legal - that's a problem. Hence my wish for 7.5" wide steels, they fall within the rules for tyres; 7.5" is max. width for a 205 tyre - end of story (for mr TÜV). I will try W140 steels next, W212, W211 and W210 steels don't clear R129 calipers. Of course I can get the 8x16" steels (R129) approved and registered to the papers. But only with at least 215/55 or 225/55 tyres - which are expensive and much wider than needed. It's complicated in germany. Many, many things are possible, but hardly ever easy to make legal... ![]() RE: W203 270cdi brakes on W124 XXX - barrote - 05-05-2015 yep i see your point , me too i intend to convert a 220CE in a STD, and the same problema i have with the engine to chose!!! if i choose the 2.5 N/A i will have to run from police every day and tecnical inspection every year if i turn it to turbodiesel. if i start with the 605 turbo no way i can get MB Portugal to "sell" me the conformity certificate wich i need to aprove the B check. going 606 is the problema with the engine size , 3000cc pay´s a lot of taxes. and the end i have the emissions issue. but that here i can go with a functional EGR and a catalitic filter and thats it. eventhough i have to tune the pump for 30cc max with the turbo blowing , to be below the 150g/km. anyhow maybe i´ll convence MB to alow me to use a 605.96X, and i go from there. if i happen to ask u for such a engine, in decent shape how much would that be? regards RE: W203 270cdi brakes on W124 XXX - DiseaselWeasel - 05-05-2015 (05-05-2015, 01:30 PM)barrote if i happen to ask u for such a engine, in decent shape how much would that be? I don't know... I tend to buy complete cars. C250TD can be had sub-1000€ ![]() RE: W203 270cdi brakes on W124 XXX - barrote - 05-06-2015 i can buy a complete car from u , if its below 1000 € wether a c250td or a E300 or the w202 6 cyl. no problema as long as it has a engine in good shape , and can make the trip to Portugal. let me know if u can help me with this. RE: W203 270cdi brakes on W124 XXX - Hario' - 09-08-2015 (04-23-2015, 11:52 AM)barrote he hario, Sorry I thought your post was a question! I now see it was a statement giving advice! Good advice. Beers, H. |
