IP for OM604 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: IP for OM604 (/showthread.php?tid=6406) |
IP for OM604 - greenmachine - 04-02-2015 Hello , i am replacing a crappy lucas pump on a OM 604 910 with a bosch M pump from a vito 110D . also i intend to mount a turbo using a outlet from a OM 605, my aim is about 180- 200 hp max . can someone tel me if i need to replace elements on the pump or for this value of Horsepower , its elements will do ?? also, does anyone know the model of the pump ? i still have to search for one :-) has any of you done this ? can you give me some assistance ? thanks a lot ![]() ![]() RE: IP for OM604 - Booster - 04-02-2015 If it's a mechanical pump then yes I think new elements are needed, if its electronic then 200 hp is fine. The 6mm elements from the electronic pump can go in the mechanical pump for no ecu 200hp RE: IP for OM604 - Petar - 04-02-2015 200hp might be possible with a 6mm pump, but just barely, remember it's only a 4 cylinder. ~180hp should be easy. RE: IP for OM604 - F.R.A.S - 04-03-2015 The Vito 2.3dt IP has 6mm elements but it's not of the same type as the electronic 6mm so they can actually not deliver more then max 55cc of fuel I'm afraid. You need to either change that to real 6mm elements or go 7.5mm or 8mm. Otherwise the 2.3dt IP is great. High RS# and easy to mount a throttle linkage on and so on. RE: IP for OM604 - barrote - 04-03-2015 hello, Regarding the pump, i can find u one, PM me. for the turbo i belive i have one laying around, so u just miss the exaust colector, something that wont be diff. boa sorte. RE: IP for OM604 - greenmachine - 04-16-2015 ok, and for me to reach 200whp or 180whp, do i need to get diferent injectors ? which ones, or from what engine ? if using the original injectors, what do i need to change to reach that power ? thanks :-) RE: IP for OM604 - barrote - 04-16-2015 u need to pm me. i´ll help u out with that build. regards |
