OM606 Pump swap - Printable Version
+--- Forum: Pics and Videos (https://www.superturbodiesel.com/std/forumdisplay.php?fid=12)
+--- Thread: OM606 Pump swap (/showthread.php?tid=6408)
OM606 Pump swap - dieselmeken - 04-03-2015
https://www.youtube.com/watch?v=2DHD6UoALto&feature=youtu.be
RE: OM606 Pump swap - dirtyninety - 04-03-2015
Fantastic! this is EXACTLY what i wanted to know!
RE: OM606 Pump swap - Booster - 04-03-2015
Where can you get the locking tool + Timing light?
Ok Found the locking tool but no timing light?
RE: OM606 Pump swap - mytmousemalibu - 04-03-2015
I wish there was a way to get or make a cheap AB light. I could just get the fitting that goes into the pump, I could make the rest. The piece that goes into the pump would be difficult to make. I cold maybe make one If I actually had one in my hand to look at.
Otherwise I am likely to do it by spill timing. I am wondering about doing that but perhaps with air at low pressure? Listening for the air to stop hissing from the empty delivery valve holder to signal the start of injection. I could easily make a pressurized fuel vessel for this too.
Goran, any reason I couldn't use low pressure air to spill/drip time a pump to the engine?
RE: OM606 Pump swap - dieselmeken - 04-09-2015
(04-03-2015, 04:15 PM)mytmousemalibu I wish there was a way to get or make a cheap AB light. I could just get the fitting that goes into the pump, I could make the rest. The piece that goes into the pump would be difficult to make. I cold maybe make one If I actually had one in my hand to look at.
No reason at all, I just have the 2 other options that I think is better on this engine. If I have the plug for blocking device I use it of course.
