Block plug - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Block plug (/showthread.php?tid=641) |
Block plug - ForcedInduction - 08-29-2009 What is this plug? Main oil gallery, a second coolant drain? RE: Block plug - totaldisaster - 08-30-2009 oil cooler line mounting point. There's supposed to be a mounting bracket there. Are those hose clamps I see on your cooler lines?.... tsk tsk, Forced ...I'll assume its b/c of the oil bypass filter RE: Block plug - ForcedInduction - 08-30-2009 (08-30-2009, 01:02 AM)totaldisaster oil cooler line mounting point.That makes total sense. Quote:There's supposed to be a mounting bracket there.There was a bracket there. The cooler lines from the 76 300D use the engine mount arm bolts. Quote:Are those hose clamps I see on your cooler lines?.... tsk tsk, ForcedHow so? Its no different than crimp fittings, both types clamp the hoses onto the barbed hardline fittings. Quote:I'll assume its b/c of the oil bypass filterNo, oil cooler hoses from a 76 300D. http://www.superturbodiesel.com/std/oil-cooler-hose-issues-t-444.html Compare to what was unknowingly on my 300TD for about 2 years, until I discovered it during the 300TD-240D engine swap. RE: Block plug - totaldisaster - 08-30-2009 ooohhh.. pretty colors. They're rather patriotic if I do say so. I can live with that, but do we agree that you can over tighten a hose clamp and greatly depreciate its holding strength? HEY! what brand makes the orange in-line filter? RE: Block plug - ForcedInduction - 08-30-2009 (08-30-2009, 02:30 AM)totaldisaster but do we agree that you can over tighten a hose clamp and greatly depreciate its holding strength?Completely. They are supposed to be snug, not so tight that chunks of hose puke out the ribs. My method is to only use 3 fingers on the screwdriver. Quote:HEY! what brand makes the orange in-line filter?99% sure its NAPA/WIX. |
