W202 fuel supply issues. Tank strainer clogged ?? - Printable Version
+--- Thread: W202 fuel supply issues. Tank strainer clogged ?? (/showthread.php?tid=6429)
W202 fuel supply issues. Tank strainer clogged ?? - Petar - 04-11-2015
Ok so my C250 Turbodiesel wagon has been giving me some headaches.
I have once ran out of fuel with the gauge still showing 1/4 tank left !! Never let it below 1/4 tank later.
A couple of months later i was driving around and suddenly it stalled. Thought i ran out of fuel I poured some into the tank however it won't start at all. Tried the crank crank crank method and killed the battery.
I towed it home luckily i was only about 600m away. Checked the suction hose and i couldn't pull any fuel at all.
Note that i have a mechanical injection pump from an OM602 NA. I also have a complete fuel system with banjo bolts so that rules out the infamous o ring issues.
So i tried to connect the lift pump to a hose, droped the hose into a jerry can full of diesel. It started and ran OK.
That makes me suspect the tank strainer. So my question is does the W202 wagon have a tank strainer ?? I can't for the life of me find it.  Rolleyes
Also the fuel gauge has become extremely erratic now, when i turn on ignition it swings around from 1/4 tank to 3/4 tank.
RE: W202 fuel supply issues. Tank strainer clogged ?? - Hario' - 08-13-2015
Let us know when you fix it, others may have that problem in the future running off WVO / boi etc, including me..
RE: W202 fuel supply issues. Tank strainer clogged ?? - RickyE - 08-16-2015
ah the fuel tank on these w202 can be abit of a pain, they dont have a strainer though, well atleast mine didnt when i had to clean it out
just for interest try filling it right up and trying again, when i had the problem in my tank i read up on them. Because they are a saddle tank design, there is a pipe that joins both sides of the tank, it pretty much syphons the diesel from the side you fill into to the side the pump lifts from, if this pipe gets blocked or gets a hole in it, it wont syphon it accros, the only way to get around it is to fill the tank
from what i remember you can swap your feed and return lines, might be worth a try to as it returns into the same side you fill from, so it should be full of diesel
RE: W202 fuel supply issues. Tank strainer clogged ?? - Petar - 08-19-2015
I didn't fix it yet, just driving my w123 now since the W202 is not registered anyway.
Replaced the main suction hose that goes to the lift pump in the engine bay.
I did manage to get it to start but it ran for about 10 minutes and died again Dodgy   So i will fill up and try again.
Read this:
http://qclt.com/train/w202/w202/Chassis_Fuel%20SystemFueltank.htm
I am now pretty sure that both of the venturis are clogged and the fuel only gets sucked from the anti-splash container. Once 8 litres of fuel get used up and transfered to the left chamber the engine dies. Now since i got bored of cranking over i got an old w123 lift pump and pumped manually. At first i easily got a flow of fuel. But then when i started it and it died it couldn't suck anything, seems to be just air. Considering that the lift pump should suck about half a liter to one liter per minute this matches the symptoms  Idea
Now i will try to fill up and if i manage to pull fuel from the tank then i now what the problem is.
BTW when it did run a long time ago  Big Grin it would just die when you get to 1/4 tank on the gauge, left my father stranded once.
So I'm pretty sure that the syphons are clogged.
Now how do i clean them ?? I have to drain the tank trough the fuel level senders and then remove them and i can access the syphons and tubes, right ?? Somebody somewhere mentioned that the threaded fitting for the W123 tank strainer works great for this.
No wonder this happens since the fuel here is terrible, i have to clean the tank strainer on the W123 every year or two.  Exclamation Exclamation
Sorry for long post but this car is driving me crazy  Angry
RE: W202 fuel supply issues. Tank strainer clogged ?? - Tito - 08-24-2015
No nasty bacteria problem in your fuel tanks?
RE: W202 fuel supply issues. Tank strainer clogged ?? - Petar - 01-02-2016
Just wanna let you know, the problem is fixed. A plastic bag was found in the tank Exclamation
How the hell did it get there i don't know  Huh
RE: W202 fuel supply issues. Tank strainer clogged ?? - charlysays - 04-21-2016
(01-02-2016, 12:32 PM)Petar Just wanna let you know, the problem is fixed. A plastic bag was found in the tank Exclamation
Haha... mate of mine who runs on WVO had a slug block his fuel pickup!!
I've done about 85k miles on WVO in my C250 TD wagon and fallen foul of the saddle tank issue a few times.
I carry a small can of diesel in the boot just in case now.
However, if you brim the tank the range is around 300 miles down to half a tank which is really not that bad.
I've thought long and hard about how to make the tanks balance better.
Both solutions I found had downsides.
You either run a simple pipe joining the tanks underneath the prop shaft, which is vulnerable to getting ripped off.
Or you use something like a facet pump to constantly empty the return side into the feed side.
This could leave you stranded if and when the pump gets blocked or packs up due to pumping WVO.
The C250 TD doesn't have a tank strainer as has been said... there's a witches hat pre filter located next to the main filter on the engine.
