Turbocharger help - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Turbocharger help (/showthread.php?tid=6447) |
Turbocharger help - Daz - 04-17-2015 Hi there to all some help please . I am currently doing a project installing a om606 into a boat I have sent my injector pump to dieselmeken so while it is away I want to work on setting up my stock turbocharger Goran over at dieselmeken recommended 7.5 mm element and I am planning to use my stock turbo . So the question is this what is the best waste gate actuator to install on a stock turbo any help would be greatly appreciated Darrel RE: Turbocharger help - ak47is1337 - 04-17-2015 Why in god's name would you do this? RE: Turbocharger help - Turbo - 04-17-2015 In my upion if you have in mind to even bothyer with the original turbo you should tke mout a sledge hammer and let it speakso you no longer think aboutr theold one, they do not take muck before they go balistic... but this is my personal feeling about the oroginal turbo so please do not take it personal, what are your power goals? RE: Turbocharger help - Daz - 04-17-2015 Ok ok I get it do what turbo do you recommend . I was going to keep the stock turbo for one season and change. It next year I'm on a bit off a tight budget 250 - 300 hp is my goal RE: Turbocharger help - ak47is1337 - 04-18-2015 go to a junkyard and start digging. try to get something off a cummins truck, a saab 9-5 (preferrably aero) or a 3.0t audi. RE: Turbocharger help - Daz - 04-18-2015 Ok guys looks like I'm going to go with a reconditioned garret turbo out of a large daf truck what are your feelings on this ?? RE: Turbocharger help - raysorenson - 04-18-2015 Are you bolting or adapting this to the original manifold? RE: Turbocharger help - ak47is1337 - 04-19-2015 Whats the turbo model? RE: Turbocharger help - Duncansport - 04-21-2015 (04-18-2015, 12:51 AM)ak47is1337 go to a junkyard and start digging. try to get something off a cummins truck, a saab 9-5 (preferrably aero) or a 3.0t audi. Saab 9-5 is a t25 and even the Aero is way small.. Saab guys are impressed with the 19C if that tells you anything. And Audi 3.0T ![]() This has been covered a few times, theres not to much that bolts to the 606/605 manifold as its a 3 bolt KKK design. Probably need to make an adapter if you want to keep the factory manifold. Alternatively you could send the factory turbo out to Boostlab or someone and have the exhaust wheel clipped and they could possibly custom up a bigger compressor. But that's all going to cost $$ I vote the adapter route and a HE351cw or HX35. RE: Turbocharger help - Daz - 04-27-2015 Thanks very much Duncan I think the adapting route is the best Cheers RE: Turbocharger help - Daz - 04-27-2015 Bye the way I'm from Ireland . I can source loads of truck turbos the holset turbo from a daf 45 is readily available holset h1c . What do you think of them ?? RE: Turbocharger help - Duncansport - 04-27-2015 (04-27-2015, 05:07 PM)Daz Bye the way I'm from Ireland . I can source loads of truck turbos the holset turbo from a daf 45 is readily available holset h1c . What do you think of them ?? I used a h1c on my 602 and it was more then enough for that engine. Unless your going for broke i think the h1c would be just fine. There are many versions of the turbo however. I have a big h1c ill donate to you if you pay to ship it ...... ![]() RE: Turbocharger help - Daz - 04-27-2015 Wow I would like to take you up on the offer !! RE: Turbocharger help - Daz - 04-27-2015 What hp could I expect from this setup ? RE: Turbocharger help - Duncansport - 04-27-2015 The big H1C uses the same comp housing and comp wheel as a HX35 so perhaps 300is? You'll need and external gate as well. RE: Turbocharger help - ak47is1337 - 04-29-2015 what are the differences between the "big" and "small" H1C? RE: Turbocharger help - raysorenson - 04-29-2015 Probably same turbine but different size compressor wheels. The HX35 has at least 4 different compressor wheels but all have the same turbine. RE: Turbocharger help - Daz - 04-29-2015 Hi again everyone I'm still researching turbos and I have another question . eBay is full of cheaper turbos are they any good they seem too cheap and crap like any other items from China so has anyone had any experience with these ? RE: Turbocharger help - Duncansport - 04-30-2015 (04-29-2015, 10:20 AM)ak47is1337 what are the differences between the "big" and "small" H1C? Big H1C has a 57/83 comp |
