max power 722.3 can handle - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: max power 722.3 can handle (/showthread.php?tid=6457) |
max power 722.3 can handle - PedroFerreira - 04-21-2015 what is the max power that my auto gerbox can andle? can handle 300 hp? RE: max power 722.3 can handle - Duncansport - 04-21-2015 Turbobandit seems to do ok with them. Stock handle 300hp? probably not RE: max power 722.3 can handle - whipplem104 - 04-21-2015 You can push 300hp through one no problem. Just turn up your modulator if you feel soft shift under power. These were used in v8 and v12 cars from the factory. They have a few more clutches for 3 and 4 but I ran mine for years with more than 300hp. Remember it is how you put the power down that is more important. RE: max power 722.3 can handle - PedroFerreira - 04-22-2015 my setup wil be 7mm elements turbo ar60 and intercooler..the gearbox can andle 450 nm? |
