Om617 what this bolt does? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: Om617 what this bolt does? (/showthread.php?tid=6468) |
Om617 what this bolt does? - carlitosgy6 - 04-25-2015 What hold this bolt? I need a reinforcement bracket to hold a sanden 508 so i want to know if i can remove that bolt without causing something to fall inside the engine, let me know if i can use it, seems big ![]() RE: Om617 what this bolt does? - Torkey - 04-25-2015 I believe that bolt holds a guide for the timing chain. I'll look for a diagram to post. RE: Om617 what this bolt does? - Keino - 04-25-2015 (04-25-2015, 04:46 PM)Torkey I believe that bolt holds a guide for the timing chain. I'll look for a diagram to post. I don't think it does. It just holds the "timing bracket" You can remove that bolt, nothing to worry about. RE: Om617 what this bolt does? - zeeman - 04-25-2015 (04-25-2015, 04:46 PM)Torkey I believe that bolt holds a guide for the timing chain. I'll look for a diagram to post. Upper large hex bolt gives access to the oil galley plug, the low bolt holds the timing chain guide and access to the lower oil galley plug. I would come off the stock A/C mounting bosses on the block. RE: Om617 what this bolt does? - carlitosgy6 - 04-25-2015 I was thinking coming from the stock bolt location bit they are too far from the place the compressor goes, the compressor will be pulled by the belt plus will vibrate a little, thats why I want to do an extra bracket from that point, thanks everyone RE: Om617 what this bolt does? - MrHope - 04-26-2015 looks like one of 3bolts that holds the injection pump. look if it lines up with the ones on the backside |
