c220 CDI Manual - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: c220 CDI Manual (/showthread.php?tid=6481) |
c220 CDI Manual - Booster - 05-02-2015 Can this Gearbox be used on the back of a OM605? Clearly its much shorter than the auto, is there any propshaft combo you can use or is it custom? http://www.ebay.co.uk/itm/MERCEDES-C220-CDI-CLASSIC-4-DOOR-SALOON-2001-2003-2148-GEARBOX-MANUAL-/371095895220?pt=LH_DefaultDomain_3&hash=item566709fcb4 RE: c220 CDI Manual - Booster - 05-04-2015 Anyone? RE: c220 CDI Manual - Duncansport - 05-04-2015 looks like a go to me. RE: c220 CDI Manual - Booster - 05-04-2015 (05-04-2015, 10:15 AM)Duncansport looks like a go to me. would I use the om605 clutch set up etc? RE: c220 CDI Manual - Duncansport - 05-04-2015 no idea RE: c220 CDI Manual - Booster - 05-05-2015 Anyone used this gearbox before? Worth the effort or stick with the auto? Will it cope with 300-400Hp range? RE: c220 CDI Manual - Druk - 05-07-2015 It will have a DMF flywheel which will need replaced by something stronger. Too many ???? for an easy life ![]() |
