kkk wastegate stuck open - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: kkk wastegate stuck open (/showthread.php?tid=6483) |
kkk wastegate stuck open - scrubs - 05-03-2015 Hi,after boat loads of reading I've found my k26 wastegate to be stuck open I believe. I can blow through the hose without any restiance leaving me to this conclusion. Any ideas on how to get it unstuck? I've backed the wastegate out 3 turns and the stud feels very loose also. Haven't found a rebuild kit yet if it's going this direction. Any help or suggestions are welcome Thank you. RE: kkk wastegate stuck open - barrote - 05-03-2015 wich hose do u blow to come at such a conclusion? pics !! RE: kkk wastegate stuck open - scrubs - 05-03-2015 Blew through the hose going to the wastegate. RE: kkk wastegate stuck open - hooblah - 05-03-2015 Merc wastegate actuators usually operate on vacuum, not pressure. If you can suck like a whore then you might be able to find out ![]() RE: kkk wastegate stuck open - DiseaselWeasel - 05-03-2015 Uhm - 617 & 603 KKK chargers have pressure actuated wastegates... They don't have a hose, though ![]() RE: kkk wastegate stuck open - scrubs - 05-03-2015 Arrrrgggg newbie that I am....for sure. so why am would my boost be so high during acceleration, up to 20lbs. Maybe I've been misleading myself, I thought 8-12 lbs boost was the limits when correctly working. I have spent hours reading here but that by no means gives me knowledge of what I'm doing/trying. Background, om617 from 84 wagon put into a Land Rover Defender 110. All I've added, by recommendation was a manual boost controller. I've also added a functional snorkel. Future add on will be a IC and a better IJ pump when one becomes available. Have adjusted valves too It runs very well up through the RPM'S but the boost level has my attention. At 63mph it's at 10-12 at say 68-70 it's around 18-20. Can't figure out how to post pictures would if I could. And Thank you for your replys/time with this. I'd like to learn but need proper directions RE: kkk wastegate stuck open - scrubs - 05-03-2015 FWIW air can be pushed both ways easily. RE: kkk wastegate stuck open - Volker407 - 05-04-2015 If you can easily blow air THROUGH the wastegate it is broken if you ask me. There is a diaphragm inside which actuates the wastegate valve and should not let air through. If the wastegate is broken in that way it is always completely closed and you´ve got as much intake pressure as possible. As mentioned above the wastegate on a OM617A works with pressure, not vacuum. The stock pressure is specified with 0,7 - 0,8bar = 10,2 - 11,6psi With a stock pump everything above ~15psi is mostly just hot air you don´t need Gruß Volker RE: kkk wastegate stuck open - barrote - 05-04-2015 ![]() RE: kkk wastegate stuck open - scrubs - 05-04-2015 Thanks, how can it be fixed? Haven't found a repair thread yet, been looking every search word I can think of. RE: kkk wastegate stuck open - scrubs - 05-04-2015 Starting to get the SOL feeling about getting this rebuilt RE: kkk wastegate stuck open - Duncansport - 05-05-2015 So if your wastegate was stuck open you would have no boost.... RE: kkk wastegate stuck open - fordheaded - 05-05-2015 I think we need pictures to pursue this further. Which hose? RE: kkk wastegate stuck open - scrubs - 05-05-2015 I'd like to post a picture haven't figured it out yet from phone. It's the hose from the actuator that allows air to pass both ways. Have found a shop that can replace the diphram and rebuild it. Put a WTB also out for one too. |
