Schwitzer 800bhp+ ETT turbo. S363 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: Schwitzer 800bhp+ ETT turbo. S363 (/showthread.php?tid=6640) |
Schwitzer 800bhp+ ETT turbo. S363 - whitey1986 - 07-18-2015 Large alloy 0.60 a/r v-band compressor housing with 4inch inlet and 3inch outlet. Huge 96mm high efficiency 7 blade compressor wheel with ETT Extended Tip Technology and 63mm inducer capable of 800bhp+. Heavy duty oil cooled core with 360deg thrust bearing. High flow 83mm 10 blade turbine wheel (same as used in many Airwerx and EFR turbos) with 74mm exducer. 1.25 a/r twin scroll turbine housing with divided T5(?) inlet flange and 3.5in 6 bolt outlet flange. Price is £450 / $700 I can also get a price for shipping to the USA RE: Schwitzer 800bhp+ ETT turbo. S363 - MFSuper90 - 07-18-2015 Are you talking inducers or exducer on the compressor? Im going to assume exducer since a 96mm inducer s300 frame turbo is probably impossible. RE: Schwitzer 800bhp+ ETT turbo. S363 - whitey1986 - 07-19-2015 96mm ETT compressor wheel with a 63mm inducer, apparently capable of upwards of 800bhp with high efficiency. Twin scroll 1.25a/r turbine housing and 83mm wheel, 74mm exducer. This is as much as I can tell you. Bought a while ago in error far far far to big for my needs considered using to make a turbine jet. |
