606 turbo activator - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: 606 turbo activator (/showthread.php?tid=6716) |
606 turbo activator - gary andrews - 08-30-2015 are the standard 606 turbo activator good the use when you put on a super m pump. if not what to use cheers RE: 606 turbo activator - starynovy - 08-31-2015 You mean wastegate? No, its controlled partialy by vaccum also you can not set pressure without ECU. Why use stock turbo with superpump? RE: 606 turbo activator - gary andrews - 08-31-2015 so which one do i need. only starting on standard and working my way up with turbos. |
