Timming chain strech in 605/6 - Printable Version
+--- Thread: Timming chain strech in 605/6 (/showthread.php?tid=6727)
Timming chain strech in 605/6 - barrote - 09-06-2015
Hello fine people,
For those lucky fellas  who have access to VIS tool , could u be nice and send me some info about chain strech on the 4 valve engines....
I seems all people i know open na eye brow when we start talking about the chain....
Regards
RE: Timming chain strech in 605/6 - starynovy - 09-07-2015
If I recall correctly 5° is due replacement. I checked some engines well over 500 000km and stretch was 2-3° so it would not bother me much.
RE: Timming chain strech in 605/6 - barrote - 09-07-2015
Hy ,
Maybe u´re right , but what i really need is the manufacturer info , cause last time i checked it was about 5º , but i never seen or read about the procedure, on how to do it, and i not even talk about valve opening..... numbers
info of MB would be much apreciated....
regards
You do it simple, rotate engine before TDC, take off valve cover and then put 6mm pin into the hole in camshaft bearing. Rotate crank until your pin slides into camshaft sprocket. Then you read degrees on crankshaft pulley, that is your stretch.
Hy starynovy, that is more less common sense, Wink
thing is the other info they talk in the work cards , thats what i´m after .... people say 3 to 5 degrees is good! ok i know that too experience...
what about valve timing , maybe is not so bad ... daddad.
i´m really interested in the work card Smile
thanks
Well it sounded to me like you wre asking how to.. Big Grin  Dont know man, BMW prechamber unit starts to slap valves at some 7°, and noticeably looses bottom end power with each degree beyond 3°.
RE: Timming chain strech in 605/6 - barrote - 09-08-2015
thanks , but u see the BMW case!!! when i´m reving my 605 at 6k what maters is just a small valve float !!! and ddisaster strokes
hope some member can help me with that.
timing chain at MB store over here are 192€ plus 23%VAT.
maybe u want to sell me one Wink from there...
