WTB OM606 Injectors - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: WTB OM606 Injectors (/showthread.php?tid=6753) |
WTB OM606 Injectors - SurfRodder - 09-19-2015 NA or Turbo. Just need the housings as I plan to finally finish my pop tester for the 606 build. RE: WTB OM606 Injectors - raysorenson - 09-21-2015 Do you have access to shims? I mention this because the 4v head injectors don't use the same commonly available shims as the other OM engines. If shims are a pita to source, sticking with just turbo injectors would be less headache |
