W124 radiator dimensions. - Printable Version
+--- Thread: W124 radiator dimensions. (/showthread.php?tid=6791)
W124 radiator dimensions. - SurfRodder - 10-05-2015
Hello all,
  Hopefully someone has a radiator out of their w124 and can measure the available space.  I have a crack in the pass tank on one of mine and plan on upgrading to an AFCO welded aluminum one perhaps a dual pass.  Anyway, if anyone can provide the dimensions of the available space it is greatly appreciated!  I would just measure mine but they are both on base in a locked shop facility until tomorrow and I'd like to order a new one before then.
Josh
RE: W124 radiator dimensions. - SurfRodder - 10-05-2015
Well...just bit the bullet and ordered this one: http://www.summitracing.com/parts/afc-80125n
They show it as 26" wide and 19" tall with 3" thickness which may be a little thick, we'll see.  I am also hoping the inlet is close enough to just use the stock top hose and flip if 180*.  I have a hunch that I will need to go take a look at available hoses once I measure the gap between outlet of the head and inlet of the radiator as IIRC the outlet of the head is offset to the left side.
