Clutch options - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Clutch options (/showthread.php?tid=6792) |
Clutch options - LRDefender - 10-05-2015 Hello everyone, I'm struggling to find a clutch for my 606 project, it's only about 260HP and 380-400NM of torque. I have a standard OM60x flywheel. So my question is what off the shelf options do I have for a clutch that will suit my flywheel? I see there are some mentions of machining the flywheel but what is actually done to it? And what clutch is needed? Thanks, RE: Clutch options - F.R.A.S - 10-06-2015 Hi mate. The clutch is really your choice as long as it fits your transmission shaft. When you machine a FW you make this to be able to fit the pressure plate you desire. We make it 9-times out of ten or more for the Sachs 765 PP because it´s a cheap and well proven option for up to 1000Nm. And it's for a 240mm clutch so you can run an organic clutch in low power applications like your own. Remember that you need to machine the FW for the right clutch thickness and when done the lot needs to be balanced. RE: Clutch options - LRDefender - 10-06-2015 Hi F.R.A.S, Thanks, so can you supply a FW ready to take a 765 PP? How much + shipping to the UK? |
