Which Diff should I use for w124 superturbo - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Which Diff should I use for w124 superturbo (/showthread.php?tid=6797) |
Which Diff should I use for w124 superturbo - xgroundel - 10-08-2015 Hello , dear friends from my favorite forum : ![]() I have a question for you , because I can't find a decent answer from the past threads so I decidet to post new. Can you help me with the choise of the diff for my projects. W124 Superturbo - One with 606 , and one with 605. Both with 722.6 gearboxes W124 with OM104 turbo My biggest desire is for some LSD diff , but I don't have so much resources for very expensive purchases . What I can buy ready or from what i can be manufactured to have decent diff for my projects : ![]() Thank you very much !!! RE: Which Diff should I use for w124 superturbo - EmJay - 10-08-2015 Do you prefer a higher top end or faster acceleration? Good middle of the road could be a 3.23 from a 16v, had LSD. I'm wanting for my w123 a 2.65 LSD like greazzer. RE: Which Diff should I use for w124 superturbo - xgroundel - 10-08-2015 I want faster acceleration ![]() RE: Which Diff should I use for w124 superturbo - xgroundel - 10-08-2015 And where and for how much I can get LSD from 16v ... Is it that from 190e 2.3 16v.... It is very rare and expensive ..isnt it? RE: Which Diff should I use for w124 superturbo - hents99 - 10-09-2015 W124 has limited slip differential like W201 16V. They call it ASD. Internally these differentials are basically the same. ASD is LSD but with hydraulic pressure added. You can convert ASD to LSD any time. RE: Which Diff should I use for w124 superturbo - EmJay - 11-18-2015 Yes the 16v 3.23 is rare but I THINK it also came in the 2.6 sportline engines. Also someone designed a Wavetrac upgrade diff for the 16v, so new and improved is an option. Need to go to the Rev for more info on the Wavetrac. |
