Afterglow relay for 606 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Maintenance (https://www.superturbodiesel.com/std/forumdisplay.php?fid=22) +--- Forum: General (https://www.superturbodiesel.com/std/forumdisplay.php?fid=4) +--- Thread: Afterglow relay for 606 (/showthread.php?tid=6801) |
Afterglow relay for 606 - SurfRodder - 10-11-2015 Hello all. I am ordering parts to upgrade glow system to afterglow on my wagon in preparation for the 606 swap. I see that Huco crossreferences 0155453032 with their 13 2037 part. Does anyone know if that P/N actually refer to a 180 second afterglow relay? I seems like that part # is 1/3 - 1/2 the cost of others. anyway thanks in advance! RE: Afterglow relay for 606 - erx - 10-11-2015 Hi, I have that exact Huco relay and it has 15 second afterglow, yes 15 not 150 or 180. It is working fine but when I bought it I also thought it has 180 second afterglow. RE: Afterglow relay for 606 - SurfRodder - 10-12-2015 Awesome, that is exactly what I needed. Thanks for the info. I had ordered one but decided to cancel it on a hunch it was improperly crossreferenced. Ill get one with the proper MB part number on it. Thanks again! RE: Afterglow relay for 606 - erx - 10-12-2015 If you look for used relay then make sure it is switching all 6 plugs, I have two relays with one connecting bridge burnt down so one glowplug will not work with it. It seems to be quite common problem. RE: Afterglow relay for 606 - SurfRodder - 03-04-2016 (10-12-2015, 10:42 AM)erx If you look for used relay then make sure it is switching all 6 plugs, I have two relays with one connecting bridge burnt down so one glowplug will not work with it. It seems to be quite common problem. interesting...thanks for the info. I ended up getting a new one, but now it's in storage awaiting a move. |
