Dyno results - Printable Version
+--- Thread: Dyno results (/showthread.php?tid=6917)
Dyno results - scrubs - 12-08-2015
A bit back I'd found here the dyno results on a om617a with and without the M-pump and now cannot find it, could some assistance be asked for finding it again?
I made the statement that my om617 was running 250hp with the M-pump and BS was called, not having funds for a dyno found a thread here to support it
FWIW om617a, hybrid garrett T3-60mm, full intercooler,3" exhaust n little things currently forgotten but not much.
Thanks
RE: Dyno results - scrubs - 12-08-2015
Oh, 7.5 mm pump
RE: Dyno results - MFSuper90 - 12-08-2015
I have a dyno sheet from my om617 that made 125 (150 at the crank) at the wheels with the mods in my sig.
RE: Dyno results - Dark Hawk - 03-03-2016
http://www.superturbodiesel.com/std/showthread.php?tid=3644
No dyno sheet but numbers, this guy did these on his 1984 300td
"I did a base line run on dyno every thing stock it did have a exhaust leak at flex pipe but not bad. It did 81.5 hp and 159 tq automatic to the wheels bone stock w/factory exhaust and air cleaner box.
I then removed exhaust from down pipe back, put 3"cold air intake to k&n filter, deleted egr, adjusted throttle linkage to make sure going wot and deleted all vacuum lines from injector pump it did 101 hp and 197 tq to the tire."
RE: Dyno results - MFSuper90 - 03-04-2016
Something to note is that every dyno will give different number.
One might say 140hp while another may say 120 on the same car
