N/A valve and springs upgrade - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: N/A valve and springs upgrade (/showthread.php?tid=6927) |
N/A valve and springs upgrade - barrote - 12-15-2015 as in the title i´ve a set o valves and Springs upgrade for N/A head assy to turbo, 605 or 606. For superturbo can find a set of stiffer valves too drop in in 4 valve heads. regards RE: N/A valve and springs upgrade - ak47is1337 - 12-16-2015 just so you know, the m104 valve springs DO fit in the OM60x series and are stronger than stock. shouldnt be hard to find in any salvage yard happy coaling :} RE: N/A valve and springs upgrade - barrote - 12-17-2015 there is one engine model that may be made to fit, and eventhough they are not direct replacement, but we dont have many of those in here. and yes if they fit they are a way lot stronguer, they may be used in 602/3 but that is too old for me.... i dont know.... regards |
