Solid flywheel 4K Kit - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: Solid flywheel 4K Kit (/showthread.php?tid=6936) |
Solid flywheel 4K Kit - bmartins - 12-23-2015 Hello. I own a Mercedes W201 2.5 Turbodiesel Om602 and my dual mass flywheel is almost all ruined. Does anyone have references in mind from which set or whitch car should be straight fitment in my situation? I heard and i read about the 4K Kit but it is abit expensive here in Portugal.... Does anyone has one used for sale or at least just the flywheel? Thanks RE: Solid flywheel 4K Kit - hents99 - 12-24-2015 I made spacer for regular flywheel. He`s going to use .450 short shaft box. Flex-plate for starter gear, adapter and flywheel. Let`s see what happens. It`s the cheapest way at the moment. RE: Solid flywheel 4K Kit - benzguy - 12-25-2015 What is the price for the spacer? RE: Solid flywheel 4K Kit - bmartins - 12-25-2015 Uouuhhhhh....this is a engeneering mode.....please. For me its difficult to do some kind of this parts.... But ok thank you for the idea... RE: Solid flywheel 4K Kit - bmartins - 12-30-2015 Hello again..any ideas for references? What should i do? I really need help.... Mine a original OM602 turbodiesel... Thanks |
