Electric fuel pump issues - Printable Version
+--- Thread: Electric fuel pump issues (/showthread.php?tid=6968)
Electric fuel pump issues - Frank606 - 01-09-2016
Hi Guys
Thinking using a electric Carter rotary fuel pump to feed my project 606 = 500bhp 72gpm 8psi
By pass the lift primer pump will this do the job
Any advise welcome on this Thanks
RE: Electric fuel pump issues - Duncansport - 01-09-2016
Bosch 044 is your best bet. Need 2.5-3 bar fuel pressure. The vane pumps die quickly when pumping diesel
RE: Electric fuel pump issues - Frank606 - 01-10-2016
Hi Duncan
When using 044 pump do you need to fit a pressure reg to the system
As a precaution not to blow off fuel hoses
Thanks
RE: Electric fuel pump issues - whipplem104 - 01-10-2016
You absolutely need a FPR.
RE: Electric fuel pump issues - Tito - 01-10-2016
Any guys out here who tried the Chinese 044 pump? I ordered one because it was like 20 bucks. I have 0 confident in it. Just curious.
RE: Electric fuel pump issues - Duncansport - 01-10-2016
(01-10-2016, 08:01 AM)Frank606 Hi Duncan
Thanks
yep, one after the pump. a basic 3bar will do.
RE: Electric fuel pump issues - deviance - 01-10-2016
I have original new bosch pump from 3.0 TDI for cheap!
RE: Electric fuel pump issues - mcwfxx - 01-11-2016
What are in tank CDI lift pumps like? I haven't taken mine out of Vito to have a look, but I do recall 3bar mentioned. No.idea if regulated by high pressure pump return or in the lift pump. They are easy to come by in my local scrappy. But obviously a pain to fit to a tank without the large opening that many modern plastic tanks have. Hmm anyone know how they work?
RE: Electric fuel pump issues - Hario' - 01-14-2016
I'm installing an OEM BMW pump, it looks like a slender 044 and cost about 20 bucks.
http://www.ebay.co.uk/itm/BMW-E46-E39-E53-X5-3-0D-330D-530D-OEM-PIERBURG-DIESEL-FUEL-PUMP-6751867-/181987026682?fits=Car+Make%3ABMW&hash=item2a5f45a6fa:g:4sAAAOSwZG9WkhnY
RE: Electric fuel pump issues - 50harleyrider - 01-14-2016
These are supposed to be good pumps if you want external inline:
http://www.highflowfuel.com/i-10383995-walbro-gsl392-255lph-inline-external-high-pressure-fuel-pump-w-400-939-install-kit.html?gclid=CNKe8aDiqcoCFVCQHwodx50MnQ
