MB Autobox compatiblity - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: MB Autobox compatiblity (/showthread.php?tid=7087) |
MB Autobox compatiblity - ho55 - 03-11-2016 Any MB gearbox experts here? I have an OM606.962 with a 722.6 box. (From a E300 W210) But i am considering finding a 722.x box from a ML270 W134 2.7 CDI I already changed the sump to the E320 type. Do you think i will need to change the bell housing? Or will that now fit the 606 and the 320 sump? If i have to swap the bellhousing from the 722.6 to ML box does that work? Is it a big job? What about the torque converter, which will fit? RE: MB Autobox compatiblity - ross - 03-14-2016 Interested to know! I assume the sump is the rear bowl type? RE: MB Autobox compatiblity - erx - 03-14-2016 270CDI has the same bellhousing as 300td, but I think that sump bolt holes to gearbox will not match. 300td and 270CDI have the same size converter, both will fit. |
