OM606 oil pressure range - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: OM606 oil pressure range (/showthread.php?tid=7109) |
OM606 oil pressure range - matfield - 03-21-2016 Hi, I'm ordering a VDO oil pressure gauge and wasn't sure what range the engine operates in, 80psi, 100psi or 150psi are the gauge options. Thanks Mat RE: OM606 oil pressure range - barrote - 03-21-2016 0 to 8 bar ![]() the press regulating valve is set to 8 bar , well in a new pump and engine .... RE: OM606 oil pressure range - matfield - 03-22-2016 Great... Thanks for that. Mat RE: OM606 oil pressure range - Druk - 03-26-2016 I've got a VDO mechanical gauge on a 606. Never gets more than 60psi cold. Runs 50psi hot anything above 1500rpm. |
