New results for EDC Pump - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: New results for EDC Pump (/showthread.php?tid=7355) |
New results for EDC Pump - bruno_pinho - 08-12-2016 Hello New Dyno with my OM605, 7.5 elements EDC Pump. I think unusual the power line to stay until the end rpm, something that is not seen every day. Maybe try more rpm's soon. RE: New results for EDC Pump - baldur - 08-12-2016 Pretty narrow torque curve, with torque peaking at 4500 I'm not surprised to see the power still climbing at 6000. What turbo are you running? RE: New results for EDC Pump - bruno_pinho - 08-12-2016 (08-12-2016, 09:35 AM)baldur Pretty narrow torque curve, with torque peaking at 4500 I'm not surprised to see the power still climbing at 6000. What turbo are you running? Running HX40/35 with small AR63 housing RE: New results for EDC Pump - street_666 - 08-12-2016 Whats about the presuress back and inlet RE: New results for EDC Pump - bruno_pinho - 08-12-2016 (08-12-2016, 02:59 PM)street_666 Whats about the presuress back and inlet I dont know I do not measure EGP and EGT RE: New results for EDC Pump - starynovy - 08-13-2016 Why it would be unusual? With EDC you CAN inject full fuel and then shaprly cut off at rev limiter. But I take it is unusual for RSF governors where you just cant and power will fall before rev limiter bcs thats how mech. governors work. RE: New results for EDC Pump - barrote - 08-13-2016 what about a mech governor without REV limit!!! ; RE: New results for EDC Pump - baldur - 08-13-2016 (08-13-2016, 03:51 PM)barrote what about a mech governor without REV limit!!! ; I wouldn't dare run a high performance engine without a rev limiter. You want that rev limiter to save your engine when the drive train blows apart or tyres suddenly lose their grip. I know people have done it, but I firmly believe a rev limiter extends the life of a high power engine. RE: New results for EDC Pump - bruno_pinho - 08-13-2016 (08-13-2016, 02:18 PM)starynovy Why it would be unusual? With EDC you CAN inject full fuel and then shaprly cut off at rev limiter. But I take it is unusual for RSF governors where you just cant and power will fall before rev limiter bcs thats how mech. governors work. When I say unusual, I mean in general not ace edc pump....usually the power falls between 5000 and 5500 rpm.. RE: New results for EDC Pump - bruno_pinho - 08-15-2016 Which maximum rpm´s that can make a om605 stock with setifer valvule spring? |
