om603 turbo what used clutch ? - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: om603 turbo what used clutch ? (/showthread.php?tid=7356) |
om603 turbo what used clutch ? - jarow123 - 08-12-2016 I have om603 turbo with 370nm with stock cluth , the question is with which the clutch sitting there, some strong, manufactured by Mercedes? or I only use ceramics cluth ? ? ![]() RE: om603 turbo what used clutch ? - F.R.A.S - 08-18-2016 Get a flywheel and pressure plate from a 270cdi ![]() RE: om603 turbo what used clutch ? - JoeB - 08-19-2016 (08-12-2016, 02:47 PM)jarow123 I have om603 turbo with 370nm with stock cluth , the question is with which the clutch sitting there, some strong, manufactured by Mercedes? or I only use ceramics cluth ? ? What gearbox do you have behind your OM603 and what vehicle is it in? |
