om603 with flywheel from 300E - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: om603 with flywheel from 300E (/showthread.php?tid=7388) |
om603 with flywheel from 300E - jarow123 - 09-03-2016 Hello I plan to use a flywheel from W124 300E 240mm to my om603. The question is did someone already? , The clutch will work properly? RE: om603 with flywheel from 300E - benzguy - 09-03-2016 I have one in 87 300D it works good I think is the best you can use in 603 because it takes the biggest clutch disc |
