M103 FW + OM606 + sprinter clutch - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: M103 FW + OM606 + sprinter clutch (/showthread.php?tid=7391) |
M103 FW + OM606 + sprinter clutch - Suitko - 09-05-2016 Hello. Few days ago i swapped my autobox for manual trans. I have M103 solid flywheel fitted with stock M103 clutch, but it is slipping even on stock settings. I am aiming for around 300hp in future, so looking for clutch to upgrade. I found valeo kit for sprinter 826694, which should be ok at least for now. My question is, how much of step i need to take off from flywheel in order to pressure plate engage and disengage fully. I am trying to find that out for last 3 days but no success M103 flywheel has mounting edge much higher than smf flywheel for sprinter which is the clutch kit designed for. Thank you very much ![]() RE: M103 FW + OM606 + sprinter clutch - capflya - 09-06-2016 If the sprinter clutch is for a dual mass flywheel it probably won't work properly with the m103 flywheel ( you said solid flywheel). Would probably take a lot of machining to work if it would work. You can get stronger pressure plates for the m103 flywheel that would probably solve the slipping. If you're going to machine the flywheel get the Sachs 765 pressure plate and clutch disc, that is a proven combo and a lot of people use that. RE: M103 FW + OM606 + sprinter clutch - Suitko - 09-07-2016 The sprinter pressure plate is for SMF flywheel. PP765 is very expensive and also needs a lot of machining to FW. I can get sprinter clutch disk + pressure plate for 1/3 price of PP765 so thats why i am asking. RE: M103 FW + OM606 + sprinter clutch - MrHope - 10-19-2016 when you fix the clutch you will probably just break the gearbox =) RE: M103 FW + OM606 + sprinter clutch - SurfRodder - 10-19-2016 just to be clear: you have an OM606 + M103 flywheel and you want to use a Valeo dual mass to single mass conversion clutch? which transmission do you have behind the engine? I am assuming you have a transmission designed for single mass clutch, maybe 711.x series. If so, your best bet is sourcing a PP and FW for the M103 that is upgraded...that would perhaps be a little more expensive than the one you have in mind, but a whole lot easier and likely would last longer. RE: M103 FW + OM606 + sprinter clutch - soltysrsz - 10-21-2016 you want to mount this kit with m103 flywheel?? so i wouldn't do it because i have mounted valeo kit in my car, i thought it can hold about 1,2 bar boost (stock turbo), but it is slipping now ![]() ![]() My setup: -valeo single mass flywheel conversion kit to dual mass gearbox from sprinter 2,2cdi -stock turbo -2,47 diff with 225 tires ![]() -717.450 gearbox |
