om606 G Starting problems - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: Projects (https://www.superturbodiesel.com/std/forumdisplay.php?fid=14) +--- Thread: om606 G Starting problems (/showthread.php?tid=7436) |
om606 G Starting problems - wouter - 09-26-2016 hello i'm new here so bare with me i recently completed my om606 8mm pump with hx35w project i got the pump from Dpumpuk and also the exhaust manifold runs great pulls like a dream whit a g250 manual trans (i know it will not hold for long) used the clutch of the same car had the disc layed with copper now here is the problem when i start it starts very nicely but after 5seconds it dies and to restart it takes a lot glowing and starting to get it running again any thoughts ? sorry for my bad english i'm from belgium RE: om606 G Starting problems - Evgeniy1987 - 09-27-2016 And... When it runs again.. does it run well ? 2nd question: where in BE do you live? RE: om606 G Starting problems - wouter - 09-27-2016 yes when it runs again it runs great merksplas near turnhout RE: om606 G Starting problems - Evgeniy1987 - 09-27-2016 For me.. it is like you are having a minor leak somewhere, and then get some air in your system. (Heerlen - Turnhout is 110 km.. we might visit each other one day) RE: om606 G Starting problems - wouter - 09-27-2016 that was my first thought too so i put some check valvs on the fuel lines no change and the pump is totaly dry (looking forward to it ) RE: om606 G Starting problems - Evgeniy1987 - 09-27-2016 I am not very sure whether the inline-pumps have it, but the VP in my Scirocco has it: a 0.55 mm banjo bolt at the return from the pump to cause internal pressure in the pump... Not that you accidentally mounted a wrong one or a too big one or something ? Would is be easy for you to try it with an electrical pump ? Just to be sure that the mechanical lift pump is not the problem. (if you don't have it already) RE: om606 G Starting problems - wouter - 09-27-2016 it does have a presure banjo bolt have replaced it already dpumpuk thought that was the problem too but no change i also have instaled a presure valve on the return line right after the banjo bolt it opens at 1.2bar again no change by electrical pump u meen the lift pump of the elec pump ? i have switched out the mech lift pump (whit the hose fitting and treads) had a spare one sitting on a 603mech pump but again no change was thinking of instaling a lift pump at the tank as its the 463tank (plastic) it has the mounts to place one from the 230ge and i have a lift pump some where :p i'll try that see if it helps or not RE: om606 G Starting problems - NZScott - 09-27-2016 Not your shutoff actuator line connecting to vacuum is it....I did that yesterday...woops RE: om606 G Starting problems - wouter - 09-28-2016 (09-27-2016, 06:31 PM)NZScott Not your shutoff actuator line connecting to vacuum is it....I did that yesterday...woops have done that before too :p not the case this time have instaled the electronic feed pump at the tank i have too turn in on/off manual but thats even worse ?? so i turn on the pump glow and start it fires up and dies after a bit not to start again ....... let is sit for an hour and i can try again so then i started expirementing turn on the pump glow start when it runs turn of the pump and it struggels a litle and then it runs smooth...... RE: om606 G Starting problems - MrHope - 10-03-2016 Do you have a ingnitonkey operated stop vaccum? if you set the 2 vacccum lines wrong it will do that. Try remove the small vaccum line on the stop and see if there is any difference.. do you have 100% banjo or plastic o-ring fuel lines? as 605/606 standard? RE: om606 G Starting problems - wouter - 10-03-2016 the ingnition din't have a vaccum shut off so i used a electronic valve that opens when u turn the key whit 100% banjo what do u mean by that all fuel lines ar rubber no plastic lines RE: om606 G Starting problems - MrHope - 10-04-2016 (10-03-2016, 01:15 PM)wouter the ingnition din't have a vaccum shut off so i used a electronic valve that opens when u turn the key ok, do try to start with the vaccum hose disconnected from the stop on pump. did you replace whole fuelfilter holder and all fuel connectors to 603 style with banjo fittings? if not its wery common that there is a air leak in those plastic connectors an fuel will drain when car is sitting over night. i have had that trubble on a 605 before. RE: om606 G Starting problems - wouter - 10-06-2016 disconected the vaccum line no change i have a pressure banjo bolt on the outlet of the pump and after that a pressure valve since i'm not using the 603/606 filter housing RE: om606 G Starting problems - starynovy - 10-07-2016 But when it runs and you drive it, then you start it in lets say hour or two it goes good? This sounds to me like major diesel leak. Over night fuel goes from IP back into tank, when you try to start it will burn last remnants caught in elements and then it is good known story of M pump filled with air.. takes a loooot of cranking. No one-way valves will help you with this as it can leak to tank via fuel return. You need to reseal whole injection system, electric lift pump is always good idea. RE: om606 G Starting problems - wouter - 10-08-2016 if i stop the engine for longer that 20/30min it doest it again it does have a check valve right after the tank and i instaled a electric lift pump thats even worse? if i let the pump on it dies what i do to start is now turn the electric lift pump on for 4 seconds then glow for about 6seconds and the start it doesn't work evry time if i let the electric lift pump on it start and dies again too ? even if im driving i turn it on it dies?? . RE: om606 G Starting problems - starynovy - 10-08-2016 Well.. stupid thing but did you mount that electric pump right way? When you disconnect hose at injector pump and then run electric pump does the fuel pours out? When the engine is running do you see airbubles in transparent lines? RE: om606 G Starting problems - wouter - 10-08-2016 yes its the right way i can't see airbubles i don't have ant transparent lines |
