OM605 Clutch upgrade options / opinions - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: OM605 Clutch upgrade options / opinions (/showthread.php?tid=7438) |
OM605 Clutch upgrade options / opinions - juggs - 09-27-2016 Looking for a clutch upgrade on my w202 OM605, Recommendations ideas welcomed!?! ? Car is w202 OM605 with around 200-240bhp. 6mm EDC pump maxed out, remap & 2871r turbo. Currently stock 5 speed manual,dual mass & clutch. 240mm if I'm not mistaken? Just started to slip. Hope to retain dual mass to save my apparently weak 5speed 717.460 & maybe upgrade to 716.64 6 speed later date I can get heavy duty paddle friction plate, but my question is has anyone on here used this with stock dual mass & pressure plate? Is this a waste of time, is it more likely to be the clamping force not enough causing the slip? What other options do I have? Was thinking out loud use paddle clutch plate stock fitment, combined with possibly a sprinter or a C270cdi pressure plate & cover or is it incompatible? Does anyone produce a heavy duty pressure plate or clutch setup that does not cost the earth & not a 400+ Bhp capable unit. Any help appreciated ? RE: OM605 Clutch upgrade options / opinions - barrote - 09-28-2016 Hy there, if u intend to install a 716 u´de better to use the W210 C270CDI, and in this case u can purchase the flywheel /clutch is plug and play , if u fear it will slip , install a sinter friction disk. its expensive but will hold that power u are talking about. Fellas have reported the installation of sinter pads in the original 250TD clutch pack with success. For more power, its difficult to say.... u got to go customized.... RE: OM605 Clutch upgrade options / opinions - juggs - 10-02-2016 Thanks for the reply, I have found a few options so far I'm looking at retaining the stock flywheel, buy a new oem Sachs clutch kit. Keep stock pressure plate & flywheel, get the friction plate rebuilt with high copper content heavy duty friction material at a place where they build clutches for earth movers etc. Sorry I'm a bit confused about the comment about the 716 gearbox. Do you mean get one from a w210 Cdi? Or from a w203 Cdi? Is one a more direct fit than the other in a w202? RE: OM605 Clutch upgrade options / opinions - Tobulus - 05-01-2017 What did you do? I have the same Problem on my brothers 605. Little remap and now the clutch is slipping. I am looking for a clutch upgrade and still using the stock flywheel. No more than 200HP / 1.5bar boost. Maybe someone has a solution to this. |
