KKD Manifold, HX35 Super, PPD 7.5mm pump, Wastegate - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Other (https://www.superturbodiesel.com/std/forumdisplay.php?fid=19) +--- Forum: FS / WTB / Buying guides (https://www.superturbodiesel.com/std/forumdisplay.php?fid=8) +--- Thread: KKD Manifold, HX35 Super, PPD 7.5mm pump, Wastegate (/showthread.php?tid=7445) |
KKD Manifold, HX35 Super, PPD 7.5mm pump, Wastegate - HughF_UK - 10-02-2016 I've got the following items for sale, I don't do anything with Mercs anymore so it is time for this lot to go, I keep tripping over it. It is all unused, never been run up. The manifold and turbo are ceramic coated. Part built downpipe & wastegate dump (in steel with V-band on hot side), oil feed and drain are included. Pasi built the pump with 7.5mm elements from Tomnik (and 7mm DV's), running about 120-130cc at the mo. Has an external alda kit (vertical and horizontal) from Dieselmeken. Prices are: Manifold - £550 Turbo - £500 Pump - £650 Items located in the UK. Worldwide shipping available with sensibly marked invoices. I'd prefer bank transfer really but PayPal gift will do at a push. I will add pictures tomorrow evening when I'm back at the shop. RE: KKD Manifold, HX35 Super, PPD 7.5mm pump, Wastegate - hummermaniac88 - 10-02-2016 The Manifold is good for a W463 fitting with T3 mount? RE: KKD Manifold, HX35 Super, PPD 7.5mm pump, Wastegate - HughF_UK - 10-03-2016 All items provisionally sold... thanks. |
