(VIDEO) 0-60 300SD W116 5 speed HX35 OM617 - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Engine (https://www.superturbodiesel.com/std/forumdisplay.php?fid=7) +--- Thread: (VIDEO) 0-60 300SD W116 5 speed HX35 OM617 (/showthread.php?tid=7489) |
(VIDEO) 0-60 300SD W116 5 speed HX35 OM617 - 300sd/5speed - 10-29-2016 https://youtu.be/o_tFXbE6JwU 1979 300sd 0-60 in around 9 seconds HX35 turbo that everyone said categorical could not would not work! Works good for me! Factory mw pump adjusted the right way. M110 flywheel revs freely but vibrations are evident under certain conditions i will be going heavier. 5 speed 717 from w123. Opinions and question are welcome! RE: (VIDEO) 0-60 300SD W116 5 speed HX35 OM617 - NZScott - 10-29-2016 That's pretty damn good for a stock element pump! RE: (VIDEO) 0-60 300SD W116 5 speed HX35 OM617 - 300sd/5speed - 10-29-2016 That's pretty damn good for a stock element pump! Thanks Man, auto to manual took 2.5 seconds off the 0-60 time, i hope the heavier flywheel doesn't impact performance too much, but a 7.5mm pump should fix and losses when i eventually get one, what flywheel do you use NZscott? |
