722.6 Output flange shims - Printable Version +- STD (https://www.superturbodiesel.com/std) +-- Forum: Tuning (https://www.superturbodiesel.com/std/forumdisplay.php?fid=6) +--- Forum: Drivetrain (https://www.superturbodiesel.com/std/forumdisplay.php?fid=9) +--- Thread: 722.6 Output flange shims (/showthread.php?tid=7517) |
722.6 Output flange shims - matfield - 11-28-2016 Hi, Can some one tell me the part no. or dimensions of the output flange shims on the 722.6? Also does anyone have and EPC drawing of where they go in relation to the output flange, and the output flange nut; i.e. before the flange, or between the flange and nut? Thanks Mat RE: 722.6 Output flange shims - Evgeniy1987 - 11-28-2016 ![]() Would this help you ? RE: 722.6 Output flange shims - matfield - 11-28-2016 That looks good... by the looks of things there, the shims I'm after are #270, this seems to be behind the oil seal and a circlip though, is this correct, or can the shims be pulled out when the output flange is removed? The reason I'm asking is I have quite a lot of play in the rear output flange and was hoping i'd lost a shim when having it machined. RE: 722.6 Output flange shims - Sultzi - 11-28-2016 Page 39 http://www.w124performance.com/docs/mb/transmission/722.6/trans_722.6_ATSG_2004.pdf RE: 722.6 Output flange shims - matfield - 11-28-2016 That answers all the questions... Thanks Sultzi. According to Page 39, the shims can't just fall out, the Circlip would have to be removed, so I'll check the bolt again, and make sure its tight. Thanks for the replies!! Mat |
